One weird thing I just now noticed (shows how little I've been able to play with this desktop) is that even though I set CL to 17 it runs at 18:
Humm, if I set it to 16, it goes to 16:
I'm trying to decide on speed vs keeping it at 1:1. My guess is unless I could hit ~4800, it's probably better to keep it at 1:1?
Interesting, looking back at my 3700X notes, I settled 12 minute Prime 95 128k FFT stable at 4125 at 1.30v set (maybe 1.24v load). So that's kinda right in their range too.
I've still not been able to confirm or deny a rumour that on the 3900X one CCD is a good bin, the other is a lower bin. So if going for all core, you're going to be limited by the lower bin CCD if this is the reality. I still don't have any intent to get one in short term, but if anyone has one it would be interesting to see if the two CCD OC differently.
It's tough to compare with you considering the testing isn't really default/preset P95.Just how much cooling do these need?
P95 small FFT with a recent version is close enough. I don't find Aida64 to be that stressful on the CPU, so only ever use it for ram. And I think I've found better anyway.It's tough to compare with you considering the testing isn't really default/preset P95.
These things are all absolute duds when overclocking.
I have no idea why my better cooling using a 'less stressful test' in AIDA64 yields 30C more. This is across multiple boards, mind you. I can't say I like the mount for AM4 on the H150i, but right now I'm using the Intel 115x mount on the ASRock X570 ITX board and the temperatures are remarkably similar... so its not the mount it seems. TIM applications are consistent.P95 small FFT with a recent version is close enough. I don't find Aida64 to be that stressful on the CPU, so only ever use it for ram. And I think I've found better anyway.
We do... but this confirms it with even more samples with more empirical testing. Just adding more information, Dave!I thought we already knew this. They run nice and fast with the RAM set to XMP and PBO enabled but aren't much fun to play with.
And those results are horrible.
1.25 I can pull 4.35. I know my CPU is good but there not even pushing it.
So are their highest binning able to hit the 4.5 golden chip clocks we are starting to see? Or were they using a cheap AIO and that's all she's got even though the CPU has more left. If your paying that much for a 3900x binned your not using an AIO.
Their QVL information is listed: https://siliconlottery.com/pages/amd-matisseYou have a nice chip.
I don't think mine will even do 4.35Ghz (all core/smt high stress) with 1.35v (+.10v) above yours.
I think the Silicon Lottery results are fairly representative of what is actually out there. I would think that they are stressing with the latest version of Prime95 small fft (using full avx) without an avx offset. It would be interesting to actually know what their test bed setup is for binning Ryzen 2? (Motherboard, memory speed/timings, dram kit and cooling?) And also what kind of LLC was being applied? We know the set BIOS vcore for the binning levels but we don't know what the actual idle and load vcore readings were for those various binning steps/levels?
They may be testing with a higher end AIO? And I agree with you that the Ryzen 3000 series can benefit from big water cooling maybe the 3900X even more so... I'm thinking most (or at least more) of the better quality chiplets are going towards the 3900X.
On a side note...
I noticed that AIDA recently up graded their test suite in the latest version to include more high stress AVX components... Probably still not as hard/sressful as the most recent Prime95 small fft (full avx) but AIDA cpu/fpu (only) can bring up the temps.
CPU Cooler:
Any AIO CLC liquid cooler or custom water loop with at least 240mm of radiator space.
Thermal Compound:
ARCTIC MX4
Gelid Solutions GC-Extreme
Noctua NT-H1
Thermal Grizzly Hydronaut
Thermal Grizzly Kryonaut
Motherboard:
ASUS X570 Crosshair VIII Formula
ASUS X570 Crosshair VIII Hero
ASUS X570 Prime X570-Pro
ASUS X570 Pro WS X570-ACE
ASUS X570 STRIX X570-E
ASUS X570 STRIX X570-F
Gigabyte X570 Aorus Xtreme
Gigabyte X570 Aorus Master
Gigabyte X570 Aorus Pro
Gigabyte X570 Aorus Ultra
Memory:
Dual Channel DDR4-3200 (Up to 4 dimms single or dual rank)
Dual Channel DDR4-3333 (Up to 4 dimms single rank or 2 dimms dual rank)
Dual Channel DDR4-3466 (Up to 2 dimms single rank)
Dual Channel DDR4-3600 (Up to 2 dimms single rank)
