AMD Ryzen Tool Kit
Johan45
There's a ton of info floating around the web and in this forum. I'll try to attempt to bring it all into one post here. If anyone finds anything useful just post it here and I'll add it to the OP.
Let's start with the basics
Maximum temperature before throttling is 95°C, reading from the Tctl this gets it's info from the on die sensors. HWInfo 64 pictured below
AMD recommended voltage is 1.35V 24/7 and up to 1.45V which may affect the longevity of your CPU
Here's a chart pulled from the XOC guide developed by elmor for the CHVI showing voltages and limits
AMD AM4 chipset drivers without board specific installer this one includes the Ryzen power plan. http://support.amd.com/en-us/download/chipset?os=Windows 10 - 64
AMD Ryzen Master Tuning Utility https://www.amd.com/en/technologies/ryzen-master
RAM:A big question is usually what ram do I buy or will my current ram work. Someone has been kind enough to put together a site to help. I haven't personally used this but I see my ram sticks listed there. It's organized in different searh parameters so you can search your ram and find compatible boards or vice versa. http://rymem.vraith.com/
Installing Windows 7 http://www.overclockers.com/forums/showthread.php/781091-AMD-Ryzen-Win7-ISO-Guide
Editing P-States http://www.overclockers.com/forums/...air-VI-P-State-modification-for-power-savings
Overclocking Guide http://www.overclockers.com/amd-ryzen-overclocking-guide/
Woomack
Benching Team Leader
Funny ( or sad ) is that we are repeating most of that in almost every ryzen thread and there are constantly the same questions. I don't remember as simple platform to set as Ryzen in last years. There are really barely any settings and overclocking is limited to the point it's working or not and if it's not then it's clear you can't make more.
Still good to have all in one thread/post :thup:
