- Apr 19, 2012
People haven't needed to post specific threads because the are in every other post we have about then when Overclocked .
This is ocfourms after all
Off the top of my head
Low OC headroom (no OC head room on top their CPUs)
Low ram speed hurting Infinity fabric speeds
Boards bricking
Temp offset
65w parts somehow pulling more or same from the wall as 95w parts
Nvidia driver's on ryzen.
Low IPC even vs 5+ year old Intel chips
Bad ram support
Can't change secondary timings
Lower PCI lanes
Botched and delayed mounting for most coolers
Low 1080p fps (most ppl still use 1080p)
No motherboards available
Not a full product stack at launch
Cold bug
That's all I can think of in this early morning fog of someone who doesn't doesn't even own the product.
Wow that's an impressive list!! Looks spot on.
Low OC headroom on top chips.... nothing new
Low Ram speeds hurting Infinity fabric speeds.... Not sure who really cares (if we talk average people)
Boards Bricking.... Not AMD's fault bios writters release **** before good testing
Temp Offset.... Again nothing new here
65W parts pulling more or the same from the wall...... The wall identifies entire system wattage not just cpu
NV Drivers on Ryzen...... Nothing new with driver support. (waits for updates)
Lower IPC than 5+ year old chips...... (would ask for proof, but would the evidence make a "average user" aware?)
Lower PCI lanes...... Meh, most "average users" don't even know what a PCI lane is.
Can't change secondary timings....... Most "average" overclockers don't even touch these and experimenting users usually brick their OS from this anyways.
Botched Cooler mounting for old *** coolers....... Buy a new cooler or use the one supplied.... see above no OC headroom on top chips.
Low 1080P fps...... Eyes usually can't see past 30 fps (the typical argument) While AMD focused on higher resolution game play as seen in demos.
No motherboards available....... Well the statement is false. There isn't a large variety of motherboards available.
Not a full production stack at stock........ Never has this happened before. Always release top CPU and other lower end parts later. Don't make money selling low end parts at release.
Cold Bug....... SHEEEET?! Dealt with this so many times with AMD, it's not funny. BUT it's not really a cold bug, it's the nature of 14nm FinFet. These chips post in the cold. Already seen LN runs.....
But there's always goods and bads. I'm not going to argue that point.
About the gaming...... It seems to be very comparable to my i5 4690K. It's a nice increase in AMD performance if we compare to past AMD chips. This is where the "Breakthrough" comes to play. Where we try and concentrate on the positive and good things vs staring at low memory speeds and memory support. I however did not encounter most of the list above. Posted right up. Installed OS. Used stock cooler and runs pretty darn cool. No real need to overclock honestly. If we concentrate on average users, most have OEM setups. Everything in the list above becomes null. I'm the only one person in my entire family that overclocks. My 16 year old cares less. His laptop boots and runs and never seen a bios update. However the Bluescreens after memory swap on Intel laptop caused bluescreens..... that damn memory support BS factor. Oh wait..... we are aiming at AMD here. Ooops.
