AMD's factory watercooled GPU's: any maintenance required?
magellan
Do these factory watercooled GPU's need any maintenance of the water cooling system (e.g. cleaning/flushing the rad and pump)?
Janus67
Benching Team Leader
Likely not, I imagine they use the same type that you have on corsair coolers that aren't really meant to be tampered with. Assuming you mean a hybrid cooler and not a hydrocopper.
GTXJackBauer
USA
Well, it all depends if you're talking about a AIO GPU or a custom waterblock. A AIO is maintenance-free while a custom waterblock should get flushed pre-installation just in case there's debris left over from the manufacturing process.
