an35n ultra dual channel no go
waver123
Well since my barton doesn't quite work well with my old nf7-s rev1.2, I put in the shuttle an35n ultra that comes as a bundle.
The board would run fine with single channel @ 200mhz (200 x 11 for my barton) 2-2-2-11 with either one sticks of my 2 hyperx 3000 or corsair 3200LL in either slot 1 or slot 3. The board would fail memtest86 test#5 everytime if I put in 2 sticks of hyperx 3000 or corsair, in either slots 1/3 or 2/3. I tried switching the order, upped the vdimm to 2.7v (max for this board), upped the voltage for the barton all the way to 1.8v, lower latency all the way to 3-3-3-11, no go :mad: it would work @ 185mhz DC @ 2-2-2-11 but that's it, not even 190mhz. Both my hyperx 3000 and corsair works fine in DC @ my nf7-s @ 200mhz @ 2-2-2-11. AAARGGHGH. I thought these nforce ultra are guranteed to work @ 200mhz. Gonna return it tomorrow for another board hope I just got a bad one
:mad: :mad: :mad:
Mine works fine at DDR400 with dual-channel at 2.0-5-5-11, but any lower and it flips out (memtest works fine, oddly, but Prime95 fails). I couldn't get it to work lower than 2.0-3-3-11 at any speed; I think the memory controller on this board is just not quite as good as on an NF7 or some of the other more expensive NForce2s.
If you can't run dual-channel at 400Mhz at any settings (try something like 3-8-8-11), your board is defective.
My board doesn't run well at all at high speeds. With dual channel, it just does not like to run at any speed.
thanks for the suggestion, I'll try it out.
I returned and swapped for another board, same problem :(, this one does a little better 2-2-2-11 @ 190mhz but that's it. Won't work at 2.5-3-3-11 or 3-3-3-11 @ 200mhz. I gave up after that.
I'm gonna try Matthias99's 2-5-5-11/3-8-8-11 later, I thought 3-3-3-11 is low enough :(
Man I'm so disappointed with this board, I guess I expect too much. I'm gonna stick with abit/asus from now on....
