- Oct 8, 2003
- North Attleboro, MA
Hi. I apologize if this has been asked 20 million times before, but I tried the search function and nothing turned up. I've emailed Shuttle support, but it's been a few days and I haven't heard anything.
I've got a new AN35N Ultra-400 motherboard, and two 256MB sticks of Geil PC3500 (DDR433) RAM. The RAM is in slots 2 and 3 (I also tried 1 and 3). There's also a Barton2500+ (locked) with a Vantec Aeroflow stuck on there, if anyone cares.
Plugged everything in and it fired right up. Went into the BIOS and looked at the settings -- the SPD picked up the RAM as 400Mhz, 2.0-3-3-6. That's correct, and I didn't see anything in the BIOS about dual channel, so I let it boot. Now, I know some motherboards give a specific message during the POST that dual-channel is enabled. However, I don't know if the AN35N-Ultra is supposed to or not! Mine just says "Memory at XXXMhz" (whatever speed I have it set at). SiSoft Sandra and MemTest86 report memory bandwidth that seems correct (over 1000MB/sec, in line with the DC NForce2s in Sandra), so I guess it's working. I was just wondering if anyone could verify that it's set up right.
Also, while the system was capable of running the full Memtest86 test suite overnight without a hitch, and 3DMark01/03 seemed fine (once I sorted out my motherboard drivers, that is; took me a while to figure out why I was getting *lower* performance than on my old KT133A), it bombed out of Prime95's "blend" torture test in just a few minutes at DDR333/2.0-3-3-6. The in-place tests (which don't stress the memory) work fine, so I'm pretty sure something's a little off in the RAM. I know sometimes NForce2 boards sometimes need a higher, uh, CAS-to-RAS delay (or whatever the last number is; I can never keep them straight), so I left it running this morning at 2-3-3-11 to see if it would work. I'll have to try playing around a bit more and/or trying each stick separately if that doesn't hold up, I guess. Hope I didn't get a dud stick, because this stuff was a great deal, assuming it runs as advertised.
It's this RAM: http://www.newegg.com/app/ViewProdu...144-514&catalog=147&manufactory=BROWSE&depa=1
Anyway, has anyone used this RAM in an AN35N-Ultra? If so, what settings did you find best? Should I try the voltage at 2.7? Thanks in advance,
