- Nov 2, 2003
- South of Boston
After getting my TwinMOS pc3700 (2x512) back, I plugged it into my system expecting to run some high fsb. What proceeded is the very definition of frustration.
I can't pick a speed better than 10x220 right now, and the only semi-stable settings I can use are 2.5-3-3-7 @ 2.9v, cpu enhancement auto. I know this ram can do DDR500 at those settings. My cpu is running great, it's even undervolted. Memtest86 won't run for a full minute before it reports an error
So after messing with that for a while I decide I'll install the modified v10 bios and give it a shot. For some reason the abit flashutility has NEVER worked on my computer. I'll install it, then when I open the .exe nothing happens. So I figure I'll just use awdflash in dos. Now my damn a: drive isn't being detected and I can't figure out what's wrong with it.
Ahhh ready to put a hole in my case (with my fist this time).
Ha, not only that, Fedex mis-delivered my entire dangerden order (cpu/gpu blocks, fans, shrouds, tubing, pump relay, as5 and more).
I need a beer
I need a beer
