Annoying network error..
Quattro
Hello!
My dad just bought a new pc it's a ready built thing by HP it's got a 3.2HT P4 in it and a gig of RAM.
Anyway. We got wireless network cards and an ADSL router.
We've now got 4 machines.
1. Ians
2. James
3. Jennifer
4. Backup
Every computer ineracts fine and can share files and access the internet perfectly apart from Backup.
Not one single computer can access it.
But BACKUP can access everything else and it can also use the internet.
But we keep getting an error message when we try and go into it's shared files or it's shared drive.
Normally we get "Network Path not found" which is usually cured by fiddling with IP numbers.
But this error is different, I got a screen shot so you can decide for yourself.
Thanks!
Quattro
Quattro
S-Shot
I can't post the pic because it was taken on a 19" monitor...
It's resolution is too high and I can't get it small enough and still be readable.
Ask me to email it to you if you think you can help.
Thanks a million.
Quattro
Quattro
The following is the error message I receive
Not enough server storage is available to process this command.
Any ideas people?
ggo
Disabled
is the server service running? it seems like something is wrong with it.
Quattro
Quattro
How do find the server service?
My dad said he set something to server mode ages ago but he can't find it.
Please help to find it!
Is it start>run> services.msc
Thanks.
mbentley
Gloriously Lead, Overclockix Chief Architect
Indianapolis, IN
Thanks.
yes, just use start > run > services.msc. then scroll down to "server" and make sure it is running and set to start automatically.
what operating systems are the computers running?
Quattro
Quattro
James & Jennifer are both running XP Pro
Backup is running XP Home
Ian is running XP media centre edition which I believe is XP Pro relabeled.
I did what you said about the server service, and it was already turned on.
Heres an interesting thing for you though.
I can't get access to "backups" hard drives.
However if I share the Jaz Iomega drive it allows full access..
Can you help?
TimDgsr
Atlanta, GA
the fact that backup is on XP home bothers me. my biggest problem with XP is the addition of simple file sharing to the OS. it totally screws the whole idea behind NTFS if you ask me, and not only that but messes up the ability to share with anonymous users with XP pro if you turn it off to gain regular ACL controls over the file system.
Quattro
Quattro
Oh right.
Can I upgrade from XP Home to XP Pro without having to format?
Quattro
Quattro
Really! So I could change it to XP Pro without loosing any data and all my programms will still work and the registry won't be completly messed up?
TimDgsr
Atlanta, GA
yeah, but that's still no guarantee that it will get rid of that error. how do you have the info shared on that machine right now?
Quattro
Quattro
I have shared the drive that I want to share. I have enabled user to change the files also.
I can't understand why I get the error when tryng to access the hard drive but it works fine if I share the Jaz drive...
