I've got a few questions about the P4C800E and its crazy voltage problems.
Based on what others have posted am I right to assume that it's okay for the Vcore to be higher than what its supposed to be at idle and lower than what is should be under load?
Is this behavior unique to these boards and if so, should I be manually setting the Vcore to account for the swings?
Are these voltage swings actually occuring or is the voltage monitor just flaky?
Are the voltages reported by the CPU-ID and motherboard monitor programs correct? The reason I ask is that in the bios I am getting between 1.536V and 1.568V for my 1.525V setting. In CPU-ID/MBM I am getting between 1.589 and 1.6V at idle and 1.488 and 1.584V under load.
