(warning long post)
Hello to all.
As the title suggests, i have decided to take the "plunge" into WC and would appreciate all the help and suggestions humanly possible.
I am rather new to building computers this being only my third, but do enjoy the whole aspect of it even the researching and reading of info. I like taking my time and making sure i do a good clean job.
I have read alot of the info over at skinneelabs and been through the stickies here aswell as reading forums from various outlets i'm looking to buy from, taking in as much as i can understand.
I have a certain theme in mind for my build that contains alot of "bling" however if certain parts will affect performance then i am more than happy to look at alternatives. Below is a list of what i currently have and the performance i am getting, also a list of what i think would work best for me for this build.
Case = Haf X - 4x 200mm CM Megaflows - 2x 140mm Aerocool Shark (1 rear exhaust/1 drive bay intake)
CPU/Cooling = i7920 @ 4ghz HT off - 1.27v (1.29 full load) H50 push/pull with CM sickleflow 120mm (push) Bitspower 120>140 adpater that seems to be acting as a small shroud as a bonus and the 140mm Aerocool (pull) rear mounted. 2hours+ Prime95 small fft = 68-71C hottest core depeding on Ambient. (Edit just did a quick hour on OCCT linpak, hottest core topped at 71C then bounced back and forth from 68-69)
GPU's = GTX 580 Hydrocopper2 in SLI (not installed yet obviously but what i'm looking to cool)
I have no plans to cool any of the mobo/chipset but will list it and other compnents that you good folks might deem necessary.
Mobo = Asus Rampage 2 Extreme
Sound = Onboard
Ram = Corsair Dominator GT - ddr3 1600 tiple channel 6gb (Cooler OCZ XTC rev2)
Drives = MDT 750gb - WD Raptor 160gb (both carried over from my previous builds 3-4 years ago)
PSU = Corsair AX1200
I'm not looking to do any heavy modding of the case and would prefer a set up that is fairly straight forward (yeah right
) for a first timer. With that in mind a single loop would be ideal for me and if multiple rads are required i can mange an extra 2x 140.1, 1 rear exhaust and 1 front bottom intake. A 120.2 is too big to fit without heavy modding? Another note is that i only have an 80mm clearance gap between the top mounting bars for the rad to the edge of the mobo. Fan noise is not too big of an issue for me as long as it's reasonable... 2k rpm, 30db max if poss.
Components that i'm looking to buy to the best of my knowledge for a 10C DeltaT.
Rad = BI GTX360 or Swiftech MCR320QP
CPU Block = Swifttech Apogee XT
Tim: Indigo Xtreme
Res/Pump = XSPC X2O 750 L/ph 12V Pump Rev2 (Prefer a drive bay combo mount to keep things simple)
Fans = CM Sickleflow 120mm or Enermax Apollish Vegas (I know i should probably go with GT 1850's but Theme/Bling factor is swaying my vote here and on paper the CM has better CFM and same S/P and Enermax also have better CFM but slightly worse S/P but not by much and far lower db rating according to retailers
) Will i see a performance hit if i painted the blades of a GT 1850 with a thin coat of UV Blue paint?
Tubing = XSPC 7/16" ID - 5/8" OD (11-16mm) High Flex Tubing : Clear / UV Blue
Fluids: Mayhems Ultra Pure H20 5l, Anticorrosive AntiCorro-Fluid 50ml, Silver Coil x2
I think i have covered everything and please accept my apologies for the abhorrently long post.
All help/feedback and suggestions are greatly appreciated.
Thanks inadvance
Jinz
Hello to all.
Sound = Onboard
Tim: Indigo Xtreme
Thanks inadvance
Jinz
