hossenfefer
- Jul 26, 2016
So, like the title says, I've been having issues where my computer will just lock up randomly. This PC is used solely for a media server. I will surf the web on it once in a while but no gaming or other CPU intensive apps. This has been happening since i built it, maybe 6 months ago, but at some point i got it so that it only happened once or twice a week. Over the last 2 weeks the problems seem to have returned with a vengeance.
In the process of troubleshooting, my original SSD seemed like it was having issues while booting up. Unable to open programs at boot, sometimes not even getting past the Asus screen, showing disk read error press ctrl+alt+del. So i replaced the original with the Sasmung EVO Pro 850. For 2 days everything was working great, so last night i put the case back together and set it back in the computer desk from whence it came.
I woke up this morning to a locked up PC. I took the case apart and set it back on the floor. I've been running Prime95 on blend since 6AM (it's been 8 hours at this point) and everything seems to be fine. I also have CPUID HWMonitor running and am concerned about the temp readings. Under the Motherboard/Temperatures/CPU it says 63C. Under Processor/Temperature/Package it says 37C. That seems like a big difference vs the other threads i've seen on these devices.
I believe my sig has the parts to my build. As far as other info...
i just have the standard case fans and AIO fans running. the front fan is probably useless as there are 7 hard drives blocking any airflow.
The AIO fans are blowing out the top.
I put my hand right in front of and behind the rear case fan and can't tell which way it's blowing air. I feel like this is probably hampering things.
PSU fan is blowing straight up into the GFX card. this probably isn't helping.
The desk in which the computer sits has a pretty tight spot for this case. The desk is definitely replaceable when we move in the next couple weeks. I imagine the airflow issue is hindered by the the rear and top vents being a little blocked, however the locking/freezing up has happened when it was just sitting on the counter as well.
i never get a blue screen or any errors. The whole thing just locks up and requires me to hit the hard reset button.
i'm on the preferred defaults in my BIOS. But i also have the Power Saving macro selected. This seemed to help right away.
OK, that's everything off the top of my head. I guess i'm looking for recommendations for better airflow if that's what i need, or if i need to tweak the BIOS, i'll need some help with that. I'll attach the HWMonitor screenshot below. Again, this is after about 8 hours of P95 on blend.
Let me know what other info i need to provide for the best assistance.
Thank you
Motherboard - SABERTOOTH 990FX R2.0
CPU - AMD FX-9590
RAM - Klevv Fit 8GB (2 x 4GB) DDR3 1600
SSD - Samsung EVO Pro 850 256
HD - 7 WD Green HD of various sizes
PSU - CORSAIR RMx Series RM1000X
Case - Fractal Design Define R5
Video Card - MSI Radeon R9 380
Cooler - SilverStone TD02-LITE
Thank you
CPU - AMD FX-9590
