- Apr 27, 2004
- Central Cali, USA
Another "New guy to watercooling thread". But I have done my homework..... I think
Hey all!! I'm new here but have been reading around this forum (and lots of others) alot lately. Anyways this is another one of those "This is the list of parts I plan on buying for my first watercooling project" threads hehe. So let me know what you think, suggestions are welcome . I've included links to all the parts' manufacturer's sites.
Pump -=- Swiftech MCP600 rev. 2
Unless someone finds a way to change my mind, this is almost definitely the pump I plan on buying. I have read nothing but good reviews about it.
CPU Block -=- PolarFLO CPU SF w/ 1/2" Barbs
I'm pretty sure that this is the block I'm gonna get. It has gotten very good reviews and looks frickin awesome too. I've even emailed PolarFLO a few times asking some questions and have got replies back (from the head guy himself, Steve!!) fast with detailed answers! None of that yes/no short answer crap.
GPU Block -=- PolarFLO GPU/Chipset w/ 1/2" Barbs
Again.... very good performer and great looks. One of the questions I asked PolarFLO was if this block would fit on my video card (ATI All-In-Wonder 9800 Pro). They said that I would have to mod the mounting block for it to work. I'm ok with this.
Chipset Block -=- PolarFLO GPU/Chipset w/ 1/2" Barbs
This part is gonna have to wait due to the fact that this block doesn't have an adapter for Intel's Northbridge HSF hooks. Steve (the PolarFLO guy) said that the adapter should be out soon though . If you have suggetions on other chipset blocks which are good performers that work with the hooks let me know and I'll check it out.
Reservoir -=- Innovatek Tank O Matic or maybe Criticool WaterPlant 6"
I'm still deciding on this one. That Innovatek res is very nice looking but pricey. In the end though I'll prolly end up with it because I like to go "all out" instead of getting the cheaper version and wishing every day I went with the other lol. I'd have to switch out the fittings on the Innovatek though since I want all 1/2" tubing and it comes with 1/4" to 3/8"(I think?).
Radiator or Heatercore -=- Black Ice Xtreme or Black Ice Xtreme II or Appropriately Sized Heatercore
This is probably the hardest part for me to decide on. Those Black Ice Xtremes are really expensive but seem to do the job very well. I've done a little research on heatercores but not a whole lot. The main thing is it has to fit inside my case (CoolerMaster ATC-201b). I'm planning on putting the rad or heatercore at the top front of the case and making two blowholes for the fans(*gulp* putting holes in a $180 aluminum case isn't exactly what I do for "fun" lol). The space I have to work with at the top of my case is about 11" L x 5 1/2" W. I would prefer to have a rad or heatercore that will fit 2x120mm fans.
Tubing -=- ClearFlex 60 or MasterKleer (To go to the ClearFlex 60 in the link, type "85" in the Find box. For the MasterKleer type "82".)
All of it would be 1/2" ID 3/4" OD w/ 1/8" wall. I'd like to get some Tygon R-3603 tubing but c'mon..... $2.65per ft?!? That's crazy. I would really like to know how well that MasterKleer tubing performs compared to Clearflex 60 or Tygon. I've only heard a few "this is great tubing comments" but not enough to make me buy it. So let me know if you have any links to reviews of it or if you have used all 3 of them yourself and have your own opinion about which is best overall. Oh yeah, how much tubing should I get?? I was thinking around 15 ft? Does that sound like a good number when you factor in the mistakes I might make?
Two 120mm Fans -=- SilenX 120mm or possibly Evercool Aluminum 120mm
Those SilenX fans are sweet but expensive. I really really like how quiet they are though.
Additives -=- Dtek Visible Blue UV Dye and Zerex Super Coolant or Super Protector
Which of the Zerex products is better for H²O cooling? I've heard the Super Protector is clear (which is nice) but I think the Super Coolant is more popular.
Misc -=- Clamps and Shroud and Innovatek Fitting Replacements
This post is getting long and I've asked to many questions already so my questions about these will be in another post.
_____________________
Well? Did I do my homework?? lol. So there it is, my first watercooling setup. All this good stuff is going in my first PC which I built about 5 months ago. I've been really happy with it except for the noise(stock Intel HSF) and the heat. Right now as I'm typing this(midnight) my CPU has an idle temp of 43c with 28c ambient . This afternoon was really hot and the CPU got up to 50c idle . So watercooling it should take that temp down a bit. I'm getting really excited about buying this stuff (but I'm the patient type lol). Once I get this rig setup I plan on overclocking this badboy but that's another story. Well thank you very much in advance and here are my system spec's (as if this post couldn't get longer hehe).......
Motherboard -=- Asus P4c800 E-Deluxe
CPU -=- Intel P4 2.8ghz 800mhz FSB
Memory -=- Corsair 1024mb XMS 3200 DDR
Video Card -=- ATI All-In-Wonder 9800 Pro
PSU -=- Antec TrueBlue 480watt
HDD's -=- 120gb Western Digital S-ata 8mb Cache, 120gb Western Digital ATA-100 8mb Cache
Sound Card -=- Audigy 2
Speakers -=- Logitech Z-680 5.1 500watt
Case -=- CoolerMaster ATC-201b BXT
Monitor -=- ViewSonic P95f+b 19" Flatscreen CRT
4 Case Blue LED CoolerMaster Case Fans
Aspire Fan Master 609 Rheobus w/ LCD
(I'll try and borrow a digicam to show you the system now)
