- Jun 28, 2002
- Phoenix, AZ USA
Answer to the "what card should I get for $XXX" question or "which card is better&
These questions are constantly asked and usually asked in such a vague manner that it is hard for someone who knows nothing about your requirements, finacial situation, or needs to recommend the best card for you.
Here is the secret to answering all your questions like...
What card is better
Is it worth it to upgrade from X to X
What is the best card for $XXX
yatta yatta yatta
This forum is packed with great information so do a search, get a bit of info for yourself and then post more specific questions if the answer to your question isn't easily found using the search function.
Here is a secret someone just taught me about searching for words under 4 letters long.
If you have something under 4 letters just add * until it is 4 characters long.
i.e. gf3------> gf3*
NV-----> NV**
What card is better
yatta yatta yatta
NV-----> NV**
