- Nov 30, 2002
- Las Vegas, NV
So, You need a case for watercooling but you are falling a little short in the pocket book? Antec 300 $50 vs Antec 1200 for $160. Ill take the 300
I purchased a 120.3 swiftech radiator to replace my 120.2. I was going to sell it, but after being lazy and letting it sit for a month, I did some measuring and got to cutting.
If anyone knows about the 300, it has 2x120mm fans (like the other cases). So I drilled out he rivets on the right front side plate that hides the cables and is the backplate for the HDD's. I then trimmed about 1/2" more on 2 sides (right side and top side) and the 120.2 slid right in I have my 120.3 hanging off the back.
I have whats in my SIG, 4.2ghz @ 1.25v which can create quite a bit of heat. I have low speed yates on the 120.3 and medium speed on the 120.2 (PC is almost silent). My temps dropped 8c with the addition of the radiator full load in linx! I now load at a 61c when heatsoaked. Keep in mind this is with a 24c ambient. I know this time of year alot of people have sub 20c ambients, Im not so lucky (infact my A/C just cut off).
