Antec 902 Mod/Cable Management
abest0
Australia
Hey guys
Been workin for a couple weeks tryin to get this thing respectable.
Installed 3 cold cathodes (2 are sound sensitive).
Mods -
- Window Mod
- HDD Cage Mod (Invisible cables)
- 4 38mm holes for cable management
Case during the day
Case during the day - curtains closed (will replace this with one from night)
Have since changed the V8 lights to Blue
My attempt at cable management =P (3 custom cut 38mm holes in the back, 1 on top and 1 on the bottom of each HDD bay)
Hidden HDD cables
The cold cathode sound module ($2 on eBay Lol)
Stupid PCI cables are the only thing i cant figure out >.< (any ideas?)
Thanks to TjHarlow for the ideas on the HDD trick and window mod.
What you guys think?
j0rd
Perth, Australia
that window mod is top rate work, also would proly be a good idea to mount the sound sense cad for the CCFLS on some standoff's to help ensure it doesnt a) move / fall and b) short on anything.
Just my $0.02 but
abest0
Australia
Just my $0.02 but
Thanks man ^_^
Yeah the board is mounted on some foam and noise reductive grommets (although it does look like its just resting on the steel xD)
Might take the top tape off (looks pretty dodgy hey? Lol)
Im thinking about soldering the Mic to some wire and sticking it next to my subwoofer ... just so it flashes at bass.
