- Sep 19, 2002
DodgeViper said:
The Lite-On TT600 may work but I just do not see that the 20 would. I want to completely remove the fans/shroud/heater core from the area around the cpu/mobo/drive cages.
I do not want air flowing from outside the case to the inside. In my drawing air flow comes from the top and out the back without mixing with inside air. This is why its so important that I have info. on the area size above the power supply. I would like a total of 8". If it means droping the P/S down and placing the bottom of the P/S near the top edge of the MOBO I will.
That's exactly how I am going to route my airflow arrangement, except at the bottom of the case. I don't know why I haven't seen it before. It just makes complete sense to me to use ambient air instead of in case air (since case air is usually a couple of degrees higher).
