Restrictive, reshmictive.
High water velocity is just as important as simple high flow rates.
The nozzles will probably cut flow rates by one third but result in lower temperatures. If DV could be bothered, he'd find that as he widened the nozzles to allow more flow through that performance would drop off.
One of the most misunderstood points in water-cooling is the belief that volumetric flow rates are all important. Yes, they are important but only to the point that there must be sufficient water mass to absorb any heat without heating up excessively (a reason why I believe that the printer micro-jet cooling technology is headed too far down the velocity only path).
I believe that there's a "balance" point of velocity vs volumetric flow rates, and while high volumetric flow rates are better, it's possible to make a water block that performs better using just 0.1gpm, than a Maze 3 using 2gpm.
