Antec is making Enermax-ish PSUs!
donny_paycheck
Inactive Super Quad Mod
Looks like the new TruePower series of PSUs from Antec bears a strong resemblance to the Enermax ATX PSUs right down to the gold plated fan guards. They even have the same power ratings! 10 bucks says if you cracked them open the Antecs and Enermaxs would share identical components.
These new TruePower PSUs come standard in the new line of Performance Plus cases from Antec.
Pretty cool! I love Antec products...they're very well made and priced very decently. The best cases IMO because I still prefer steel to aluminum.
chromedout64
Anyone know if the new Antec TruePower PSU is really just like or a slightly changed Enermax? I've read that the TruePower PSU has shown a 5V rail voltage as low as 4.6x Volts. This seems a little low just like some Enermax's. So, Antec and Enermax PSU owners, is there any truth to this?
donny_paycheck
donny_paycheck
I don't have a truepower PSU but I have some standard Antecs and a couple of Enermaxes and they all have great +5v rails. Most of them are 5.05-5.1 volts but never lower than 4.95. If you don't want to shell out the bucks for a PC Power and Cooling PSU then I'd put my money on either Antec or Enermax for quality goods.
rpc
seattle, wa
I have two of these units and whats funny is that they are merely rebadged HECs (compucase) and that these units dont show up on AMD "approved" list but the HECs do!!!
donny_paycheck
donny_paycheck
They're very new so I doubt they'd be on it. Pretty much all PSUs with 300+ watts of total output capacity are on the AMD approved list by now. The list was mainly used during the initial days of the Athlon when there were still a lot of PSUs kicking around that weren't up to snuff when it came to pushing out enough electrons on the +5 rail for the power-hungry Athlons.
Ralf Hutter
Peoples Republik of Kalifornia
I have both a TruePower 480w and an Enermax EG465P-VE.
My TruePower 480 has been in my system for about 5 days now and here's my preliminary report:
1) It's super-quiet compared to the Enermax EG465P-VE that I've been using. Loudest thing in my system now are my Maxtor D740X HDDs.
2) The PSU fan speed does vary as the temps go higher but it just barely raises the noise level. The PSU fan RPM runs at 1465 RPM at idle and climbed to a max of 1701 RPM after running Prime95 for 13 hrs.
3) I have 3 of my Panaflo 80mm L1A's (case fans) plugged into the variable fan speed connectors. They are noticably quieter, and they start real slow on bootup. They must be running near 7volts at the low end, because you can actually see the blades turning slower. They never seem to get any noisier after running under load so I don't know if they're speeding up or not (no rpm monitoring of Panaflos).
4) Voltage (according to BIOS/Asus Probe). This will be Enermax vs. Antec:
At idle: 12v= 11.904/11.84, 5v= 5.08/4.919, 3.3v= 3.328/3.25, Vcore= (set at 1.65 in BIOS) 1.632/1.632.
At load: 12v= 11.648/11.84, 5v= 5.08/4.892, 3.3v= 3.296/3.264, Vcore = 1.58/1.60
-looks like all the voltages except the 12v line are kind of the same between the 2 PSUs, but the 12v line is more stable under load on the Antec PSU.
5) Case temps under load are about 1C higher with the new PSU, CPU temps are also 1C higher.
So far I'm pleased with this new PSU. I bought it hoping it would be quieter and it definitely is so I'm happy. I wasn't having any voltage issues with my old PSU so I wasn't looking for any improvement, but it does seem that the 12v line is more stable on the Antec PSU. That's probably a good thing for us Northwood OC'ers.
Larry Quinn
Oklahoma City, Oklahoma
I've got a true 550 heading my way right now!
It may be here today...most likely tomorrow tho..
I need the juice for all the fans in my system...;)
I also started having a stability problem and decided to start changing components out to find the problem.
I noticed that my current power supply was giving a WAVERING voltage...it may be part of my problem...but the new 8K3A+ won't hurt either!
Larry
Next Corsair PC3000 mem...(2 sticks....maybe)
and an XP 2100...(after it's sent out to unlock...)
You know...when components die..it's sometimes a GOOD THING!..
HeHeHe
