- Aug 27, 2003
- Mississauga, Ontario
I just purchased a P180 by Antec. I gotta say I am totally impressed, the case is absolutely awesome. But I need some help with some components for it:
PSU:
Right now I have the PSU that is in my sig (Antec TP480), but I don't think it will do for the new system, if only because I bought it before SATA and PCI-E were the norm, so not sure if it supports it. Anyhow, for those who have the P180, the PSU mount is on the bottom of the case, and it seems that the only effective fan would be the rear of the PSU. So, I am looking for a good PSU that has a fan blowing out the rear. Also, the PSU has to have all the connectors one may need for a new generation system.
Right now I am considering the Enermax EG-565P-VE FMA V2.0 (24P) 535W, it has a top fan too, probably will be wasted, but importantly it has a rear fan. I prefer Antec but I don't know which one would be a good fit (even tho its an Antec case lol), and from what I see in the pictures, they have a big fan on top but none in the rear.
Budget is a concern, keep suggestions under $80US.
FAN:
The case comes with a top and rear fan installed already, as well as a bottom chamber PSU cooler. This is great as they are 120mm fans and move a lot of air, so no need for a replacement. However, I'd also like to add a fan in the video-card cooler, as well as the front. What are some good 120mm fans that are quiet (not ultra quiet and expensive tho) and have some sort of speed control (even if it is manual and only accesible from inside the case)? Antec says there is no need for fans in the front as the 3 exhaust fans will pull a lot of air already, but I'd like to have at least 1 fan blowing directly on the HDDs in the bottom chamber.
Argh, just saw that the vid-cooler chamber is 80mm, so that will make things easier. However my experience with 80mm fans that move a lot of air is that they are extremely loud. Is there anything affordable out there as far as 80mm is concerned that moves some air but is not annoying as hell?
Thanx for the info, and what do you guys think about the P180?
I will keep more enquiries coming on this case, as I install my stuff and run into trouble with the million and one options of the case. Still waiting for the Opteron in the mail so it will take a while.
PSU:
FAN:
