I've recently built a new system:
Asus P5WD2-Premium MB
P4 640 3.2Ghz
Antec Truepower2 TPII-550 ATX12v
connect3D Radeon X800GTO 256MB
WD SE16 250GB SATA 300MB/s
Mushkin eXtreme Performance 2x1Gb (PC2 6400)
I believe my PSU isn't working perfectly and it may have a heat problem but I wanted to see if anybody else thinks it's normal or not with this PSU. All my voltages are perfect but the Bios and Asus PC Probe II is reporting that my Power Fan is only running around 770 - 820 rpm. Is this normal or should it be faster? This PSU has one 120mm fan at the bottom. Should I change it out?
Also, I wanted to run the SiSoftware Sandra Lite burn-in wizard but it stops the test right away because it's reporting that my PSU temp is over 77C. Once it reported it was at 105C.
I've got this system running at 4Ghz now and it's stable, or as far as I know since I haven't really stressed the system to find out, which is why I wanted to run the burn-in wizard.
P4 640 3.2Ghz
