One way to help avoid condensation (and associated long-term corrosion) problems might be to fill the socket with some sort of dessicant, such as the silica gel packets that are stuck in higher-end shoe boxes or inside the shoes themselves. (These are not a real gel, more like a bunch of tiny balls.)
I haven't actually tried this. I'm just throwing out the idea for any feedback, especially along the lines of "How could you forget about such and such....you could toast your proc" If there is no feedback along those lines, I may give it a shot.
I know that filing a socket with dessicant can't substitute for good insulation, but it may help remove that last bit of evil water vapor. (The kind that creeps in over months of uninterrupted use) Salt could also work, except should a real drop of water ever creep in there, the salt would make it infinately more dangerous. I'm pretty sure silica gel is not electrically conductive when dry, but don't know if silica gel is very solulable (sp?) and if it is very conductive in solution.
Lemme know what you all think about this.
