anti freeze evaporate?
skinart
Canada
Does anyone one know if anti freeze will evaporate if i take the lid off my res or will just the water evap?
CrashOveride
Beijing, China
i belive anti freeze wiill eveap... but it leave a weird powders tuff behind... my mom's coolant tube in her har exploded... well got a hole.. and antifreeze/water was all over... it was so hot that it was ntot wet but hteyere was a white poweder type thing that came off /w water... kinda like the salt you get from sal****er when it evaps.. only im pretty sure this stuff want salt... prolly would not help temps to do th9is for a long time as i think the concentration of those chemicals... which are prolly what ruins the thermal conductivity of antifreeze... would rise... i think... someone prolly knows this better than me... but thats my thoughts:D :eh?: :D
Paxmax
I think both will evaporate, but not at the same rate. It probably comes down to waters boiling point vs. antifreeze boiling point.
S
skinart
Canada
ok so its leave the lid on the res find another way to kewl it down, thanx guyz
CrashOveride
Beijing, China
you could get alot of rods- copper or somting-that go into the res and then stick our the top... that would prolly cool it well.. but you may need to finda way to stop corrosion without hurting thermal conductivity... meh jsut a thought:D :eh?: :D
Toysrme
ummmm. The raunchy smell of antiFreeze should tell you something LoL! DO you REALLY wanna be sitting with that stuff inhaling it all the time!? Nasty.
-Toysrme
S
skinart
Canada
when its -15 out i was getting 18c full load thats with a plastic res which i just found out is insulating the water from the cold and no fans on any part of the system and no rad, I now have a steel res which i am going to mount the pump in and once it comes out of there i have a aluminum cylinder with 1/2 copper tubing wound inside of it which will be filled with water which will freeze outside and should keep it nice and kewl also.
CrashOveride
Beijing, China
where u are dose it ever get warm.. not jsut canado lol:D... im not that uneducated but wehre u are... or jsut above the comfortave temp even? if nto that is handy for cooling!!! just maek sure hte water dosnt freeze so it cant be pumped or... so it cracks whatever your have it in... that would suck:D :eh?: :D
aenigma
What the ****?I am sorry, but you need to go back to school. :eek:
To the guy with the res outside:Your antifreeze will not evaporate, and you need to use a rad and not rely on a steel container...
S
skinart
Canada
is -15 to -35 water and anti freeze mix not good enough for cooling aenigma? and Crash i am in Alberta
aenigma
I never said its not good enough for cooling.I said that a res sitting outside isn't good enough for cooling.You need a radiator if you actually want cold liquid.It wont magically cool itself, or else we wouldn't use radiators when we watercool...
S
skinart
Canada
well i dont know then aenigma, all i have is a res outside with no fans or rad and the snow or the freezing weather seems to be magically keeping the water kool
Warlord2
Bakersfield,CA
if you have the res in snow that would be good enough but you might get some better temps if you had more surface area outside like a huge res or a heatercore. I wish I had that kind of weather:(
aenigma
Well I do know skinart.Because using a rad will get you good liquid temps, just having a res outside isn't going to do much.Sure it will do a little, but what is the point if your not going to do it right?Oh yeah, and 18c under load with this alleged -35c liquid... :rolleyes:
What is liquid temp after a full day of running full load?By the way, snow is ice.Ice cubes aren't -35c so snow isn't doing much for your temps, may even be insulating...Ice is actually a very good insulator...
S
skinart
Canada
i have been folding for about 4 months now 24/7 and my temps do not vary much at all (183x10.5 1.9v) i know rad would give me better temps but this setup is working fine for me right now and has been for a while
johnnyw
Buenos Aires , Argentina
aenigma, don´t bully the chap, if he is happy with his setup just let him go.
I do not think that setup will be nice when summer comes...... I´d rather have something done to work fine avery day of the year and not to worry about the temp outside :-o
aenigma
Uhm last time I checked I am not "bullying the chap".I was trying to tell him to use a radiator , and trying to find out his temps.But he never told them.So I am done.
