- Sep 27, 2016
Hi,
Can anyone please tell me if I would get any benefit in rendering time if I upgrade my current CPU ( Intel Xeon E5620 2,4 GHz overclocked to 3,6 GHz ) to Intel Xeon E5645 2,4 ghz ? Well, as far as I know these 2 CPUs are pretty much the same, except the fact that the Xeon E5645 has 2 more cores and 4 more threads so if I buy it, I'll overclock it using the same settings I use now and get it to 3,6 GHz too.
Anyway, as far as I have noticed using CUDA render gets me about 50% faster rendering compared to CPU only render and this is the reason why I always use CUDA rendering.
Though when I did a test ( with an overclocked cpu and not overclocked CPU, so 3,6 GHz and 2,4 GHz ) using CUDA render, the render times were the same, I didnt see any time difference and this is really making me wonder if upgrading my CPU to get 2 cores and 4 more threads will improve anything regarding the rendering time.
Usually when I use CUDA render, I see that both the CPU and GPU load are about 70%.
I know it would be 50% boost when using the CPU only render option, but this is not the case Im asking for.
I would really appreciate an answer from somebody who knows for sure, somebody who understands how CUDA render exactly works.
In case this is needed, my GPU is MSI Nvidia GTX 560 Ti Twin Frozr ii OC and my RAM is Kingston 3x4GB DDR3 1600 MHz and the software I use is Sony Vegas Pro.
Thank you.
Thank you.
