is that ALL? everything else identical? wireless speakers must KILL batteries, no? or do you still plug em into power, but just audio goes wireless...?mr. roboto said:5450 has wireless rear channels
RIG RIDER said:http://justdeals.stores.yahoo.net/gs9701020403.html
http://justdeals.stores.yahoo.net/9701150403.html
http://justdeals.stores.yahoo.net/9701810403sp.html
I bought mine here and they sound great.
double negative = positiveLogRus said:NONE of the speakers or ANY Logitech products that come from JustDeals.com are NOT covered by Logitech waranty!
g0dM@n said:double negative = positive
you should restate that.
i'm gonna probably hook them up to my HDTV tonight... just haven't had the chance. can't wait to try out the HDMI digital coming out of my DVD player to my TV... then gonna hook digital out from TV to the z-5500s...Maviryk said:Unless English is not his native toungue, in which case double negative = negative.
z-5500s are awesome and make a half decent Hometheatre setup also.
I wanted to buy Z-5500 but previously I called Logitech to find out if I could RMA a bit faulty mouse that I've got from JustDeals, Logitech support told me that they will not cover anything bought from them and same goes for Overstock.com. As far as I can remember, they just don't cover it unless it was bought brand new.
Just thought I'd note that
BTW, those Z-5500 are GREAT speakers!
well if the mount isn't bad, i may actually screw into the wall. i got a laser beam finder, so i'll make sure it works out nicely IF i do it... i really wanna, though.Maviryk said:Eh... I don't think so... Unless you consider a pair of drywall screws to be "wall mounts". The standoffs have two holes for screws or bolts or something.
I'm still trying to figure out how to mount my speakers behind my projection screen.
When did you lose your laser beam?g0dM@n said:well if the mount isn't bad, i may actually screw into the wall. i got a laser beam finder, so i'll make sure it works out nicely IF i do it... i really wanna, though.
lol... nono... i meant... my beam finder is laser.RIG RIDER said:When did you lose your laser beam?
