Hello,
A first time poster here, hoping to get some informed opinion on a motherboard that seems to be largely overlooked by reviewers, the Gigabyte Z87-HD3.
I'm aiming to upgrade my current system (a Core2 Duo E8400 running at 3.6GHz) to something that can better handle photo editing programs (Lightroom, Photo Ninja RAW batch conversions). I have no intention to get back into gaming so I don't need SLI/Crossfire or even a discrete graphics card.
I'm thinking of upgrading to a Haswell i5-4670K, aiming for a mild overclock to 4.3GHz as I don't want to mess around too much with settings and heat management.
The basic Z87 board from Gigabyte appears to be the HD3, and I can find close to zero information on the net about it. Does anyone have any experience with the HD3?
From a clocking or long term reliability perspective, is it worth upgrading up one or two levels? As far as I can tell, I have to move up significantly before a board becomes more meaningfully suited to overclocking- it's not until the Z87X-D3H that Gigabyte moves from 4 to 8 voltage phases, and that is 50% more expensive than the HD3. All the other bells and whistles (more USB ports, Intel NIC, multi-graphics card support) that come with higher end motherboards don't really matter to me.
The other board that I'd be looking at would be the Asus Z87-K as it's also carried by the shop that I'm going to use. It looks pretty similar on spec, but I've not been wowed by my current Asus board enough to particulary feel like sticking with them.
Other system info:
Other system info:
- I'm going to run 2x8GB DIMMs of basic Kingston 1600 RAM- as far as I can tell, memory speed will have pretty minimal impact to photo work.
- Cooling will be via a CM Hyper 212X
- PSU is an old Corsair HX520
- Chassis is an Antec P183 so airflow is pretty good.
