- Nov 14, 2006
- Warsaw/Poland
http://www.sapphiretech.com/productdetial.asp?pid=C4D1B443-6105-4A63-85DE-1732CC9C443D&lang=eng
This is my second 280x; unfortunately, the first one (Gigabyte WindForce3), though stronger, was damaged. I was afraid, especially after reading some detailed opinions online, that the 280x simply had some problems with the chip that led to overheating and lack of stability. Apparently, that was not the case, and the Dual-X is a wonder of a card. Even on pads, idle temps sit at 35-36C, and I've yet to see 60C even under load. By default, fans activate around 40C, which is relatively quick, but the sound is still not very noticeable. Even under more serious load, the fans are louder but not obnoxious — a 'so what' kind of feel. And the price! (130 bucks shipped; used but you couldn't tell at all apart from no foil.)
According to a test report I read (sorry, no link), the card overclocked nicely up until a relatively low point and then died, though. So I'm pretty sure 50-100 Mhz on GPU is going to be viable, but I'd rather not be taking too many chances until replacements become cheaper. Still, since I had to buy some Gelid Extreme anyway, so I might as well take the pads off and replace them with paste, to take the temps a couple of degrees down for quieter fan operation.
Also will have to see if the card can go passive outside of gaming or in lighter games.
I'm led to think the Dual-X cooler must be really good.
