THANKS A LOT for your reply!! Had my doubts anyone would answer.
Can it do the following:
1. Allows you to pick several files to combine into 1 PDF, BUT before it makes the final PDF allows you to rearrange the order of the "parent" files so that the final PDF file will be in the correct order. Like if you select files A, B, C on your desktop, can I re-order them into B,A,C so that in the final PDF. page 1 is B, page 2 is A etc... ?
2. Can you extract single pages and a range of pages (making a single PDF from the extraction) from an existing PDF without having to alter/delete from the original PDF file you are pulling the pages from?
Are there any features in this software that are in Adobe and wish it had?
LASTLY for now at least, I convert A LOT of files from MS Word 2010 into PDFs, do you notice the following:
Changes formatting on MS Word Documents such that they neither display or print correctly.
