Any1 useing a GA-7DPXDW-P?
Twin_Turbo
Billings, MT
I've got (2) of these motherboards running XP-Mobile 2400s. I pin modded the motherboard to 16x and they are running cool and stable @ 2.13 GHz. You do NOT need to cut the 3rd L5 bridge to work in SMP.
Macca
Well i'm runnig the 7DPXDW+ with two XP Mobile 2600's. Running good at 17 x 133, ran them at 17 x 140 as well but couldn't stress them too much as the ambient temps here are quite high.
cmcquistion
IT Director Senior
Tennessee
I'm running that board with a pair of Mobile XP2200's at 2 GHz & 133 FSB. I didn't overclock it, much, since it is a Server.
martindemon
Canada
Can you up the CPU voltage by pin mod on this Gigabyte motherboard?
(edit)
Ok my question was answered at 2cpu :) So it can be pin modded. Interresting motherboard.
Twin_Turbo
Billings, MT
I just raised mine to 17x but had to raise the V to 1.7
I tried to O/C the FSB to 140 but it would lock in Prime 95
The CPUs are Mobile 2400s
cmcquistion
IT Director Senior
Tennessee
(edit)
You can do Vcore pin mods on any Socket A motherboard. You are basically just fooling the board into thinking the default Vcore is something else.
