OK. I admit it. I was unfaithful and went to another site. I saw a discussion where someone wondered "aloud" if we’ve reached the peak of progress in watercooling. It started me thinking - a dangerous thing, for sure!
First, the major issue that every watercooling project has had to accept is that no matter how good your radiator and fan system is, it is currently impossible to get the liquid in your reservoir lower than the ambient room temperature. The best we can hope for is to get the water temps down to something very close to the room’s temperature. Currently, it appears we are stuck with that limit. But cooler water has greater potential to cool our chips.
I’m wondering if there might be any ways to overcome this limit?
People willing to invest in refrigeration systems like the VapoChill systems can reach temps much lower than the ambient temperature of the room. As a result, they must deal with condensation. But these systems are allowing for huge overclocks – much greater than even the best watercooling system. Cooler temps create opportunities for greater overclocking.
Let me toss out a couple of iinitial hair-brained deas for giggles and maybe a little discussion:
1.A swamp cooler (Bing’s Bong) approach: Could something like this be used to cool the water temperature in a watercooling system? Example: a mister sprays water onto the fins of a radiator. Fans blow on the radiator – as in a conventional watercooling system. Would there be greater cooling within the radiator as this water evaporates? This water would be totally separate from the fluid in the loop. Problems, why sure – but think about this. What was your initial reaction the very first time you heard someone talking about watercooling a computer? Right! Is it a hairbrained concept that could ever be made to work?
2. Could an electronic TEC cooler (a Peltier device) be used to chill the water used in a watercooling system? A conventional radiator would still continue to be used. But maybe TECs could be used to lower the water in the loop even more. Maybe the water could be chilled in a separate chamber by TECs before before returning to the reservoir; cooler water = better overclocking potential.
Note: As an example, I have an ice chest that plugs into the cigarette lighter plug of my car. This thing uses a Peltier device to cool the interior of the ice chest. You put no ice in it. It can easily reach temps of 33-36 degrees.
I don’t claim that these ideas are easy. But often the practical issues can be solved if there is real potential for success.
Anybody feel like tossing in their thoughts? Think of this as an unmoderated BS session of brainstorming. How 'bout it? Are there any crazy wild-eyed ideas you've had?
If not, then this thread will die a quiet death. No big deal.
BO
BO
