Hi.
I won a Dell Optiplex GX 260 on Ebay and, was wondering if I am limited to a certain type of memory (It uses DDR Sdram)?
After reading the FAQ in the Memory section, I noticed comes in different grades than the old Sdram.
I would like to fill it up to it's capacity (2 Gb) and, was wondering if I can use two "283/566 MHz => DDR566 or PC4500" 1 Gb RAM sticks or am I limited to a certain grade.
Here are the grades from the Memory Forum.
100/200 MHz => DDR200 or PC1600
133/266 MHz => DDR266 or PC2100
166/333 MHz => DDR333 or PC2700
185/370 MHz => DDR370 or PC3000
200/400 MHz => DDR400 or PC3200
217/433 MHz => DDR433 or PC3500
233/466 MHz => DDR466 or PC3700
250/500 MHz => DDR500 or PC4000
267/533 MHz => DDR533 or PC4200
Oh! The computer is a P4 1.8 GHZ if that helps.
Thanks
Thanks
