MAIN CHEAT CODES
Change car price
Open cars.ini file in your <game dir>\Cars folder using Notepad and make the following modification:
price=10
nfsprice=10
Now, you'll be able to buy all the cars for $10.
Change mass of the car
Using notepad open car.ini file located in the <game dir>\<your car> folder. For example I.E Cars/911T/Cars.ini. Change Mass to i.e 100 and you will have a rocket Porsche.
NOTE: Before editing, you might need to uncheck read-only attribute from ini files. To do that, browse to the folder where your car.ini files is located, right Click on the file car.ini, select Properties and remove the check from Read-only check box. Also, make backup before editing!
