anyone has an Abit BE7-Raid?
oops
anyone has experience with Abit BE7-Raid? Good or bad? Because I am building a PC for a friend, she asked for overclocking and raid, I've used Abit BD7II-Raid boards and had good experience with them. But I see BE7-Raid is newer version, so should it be better?
how does the BE7 compare to IT7 MAX2 ver2.0? the boards looks share the similar spec... do they oc around the same?
I have a little problem
in mine manual under advanced chipset features set up
there is a option for "enhance DRAM performance"
but in mine BIOS there is instead a option that is called
"Differential current" whit options default 4x 5x 6x 7x
What is that ?
What is that ?
i have the same thing! what does "differential current" mean?
and will it help my ram go faster :)
