anyone have pics
Jarhead7236
on how you scrape the green thorton L2's....i got a 0334spmw that i wanna mod but am a little hesitant about doing it...a pic of someone's modded green chip would help...thanks all. btw, all i could find using the search function was brown pcb pics....
The Coolest
Senior Member
You just tke a pin or small xaco knife and scratch away the green stuff off the dots till they are shiny, then use Q-tips and acetone/alcohol to clean up the bridge and use conductive material to make a U-loop around the cut of the bridge, or fill the pit with non-conductive material and connect the bridge straight from dot to dot
Jarhead7236
Jarhead7236
ahhhh..the light comes on now...thanks...damn, i'm as dumb as i look..lol.
Milkman
NH Biodiesel master
That's all I did too, used an exacto knife to clean up the dots, taped off the dots and used white crayon to fill with, and then defogger paint to connect them, this was on my applebred but same idea for the Thorton, Let use know how it goes and overclocks, where did you get it from?
-Milkman
Jarhead7236
Jarhead7236
got it from my local store here on okinawa...gonna wait til i get back from a trip to do the L2 mod....
