Anyone here is familiar with Studio 3Dmax R4, R3, R2 ??if so i have a quick question......
_jubei_
Disabled
BROOKLYN, NY
I have a question. When I build an Object , and than part of it I extrude,
and than apply texture when it is time To Render the whole scene I get this message " The Following objects require map coordinates and may not render correctly " . How Do I set up the Map Coordinates for those objects ??????
THX
Well I know a little bit about max. You need to give a little bit more info. Like what type of object? Nurbs, polygons. And are you using the material editor or some third party skinning util.
