I need to know because I can't figure out how and it apparently isn't enough to run above 83fsb and that ios only 790 I want to get above 850mhz with this because it can't be that hard, I know other peeps have done it
This is one that's right up my alley. Wiring the CPU for more voltage works, but I need to know what the default voltage is. Also, YOU need to download this datasheet and study the pages outlining your pin layout and the voltage table (pages 18 and 87). You will need a sewing needle or pair of tweezers, a magnifying glass, some steady hands, and nerves of steel. If you goof it up, your CPU dies. If you do it successfully, you might get to the promised land with that i810 board if yours.
