Anyone Know how to fix a AGP slot for a Intel D850GB?
Sir MMPD
USA, CA
I have been trying to get my AGP slot on my motherboard to work for months, I am starting to wonder if its either broken or what.
I checked for conflicts there is none for the slot however I have conflicts for the card its self.
I tried changeing irqs moveing them to different one getting one irq free but most of the irqs i could not change for some reason.
I am sure it is not the Card I have tried other AGP cards with the same result.
I put the card in, start it Windows ME screen comes up then the screen goes black and nothing loads. Same result when i try Win XP beta.. so I also know its not the operating system.
When i do get in its 16 bit color 640 x 480 and telling me I have bad drivers. I already tried upgradeing them same result.
Basically I am wondering is it possible to replace the slot or fix this problem? I have no idea which it is.. I have Conflicts Gallore on the comp. most of them seem like there duplicates but do not show up on the device manager...
If anyone knows a way I can fix this please respond...
Thank you,
Sir MMPD
System Specs
Intel Pentium 4 1.7 GHZ
Motherboard: Intel D850GB
Sound Card: Sound Blaster Live Platinum 5.1
Video Card: Geforce 3
Current Video Card: Voodoo 5500 .. Only way I could get good picture...
Modem: US Robotics Performance Pro
Network Card: Linksys
DVD: Creative
CD RW: Creative
Hard Drive: Western Digital 60 GB
Ram: 512 MB of RD Ram
Treker
Old School Senior
Houston
I'm wondering what kind of settings you have for your agp slot in your bios, have you checked them over good?
Also what kind of conflicts are showing up on your computer, perhaps if you could give us a short list we would have a better idea what is going on.
It could be a far streatch but perhaps if you removed earlyer video drivers you might have better luck with your gf3 ?
And last but not least, have you tried updating your bios?
Well I'm outa ideas, keep us posted :)
-Trek
S
Sir MMPD
USA, CA
Well in my bios I only have 2 settings for my video card, Type of video card and ammount of memory. I have it set for 256 MB I tried 64 no real diff... and it is already set for AGP..
conflicts conflicts... you really sure you want the list lol....
IRQ 3 3dfx Voodoo Series
IRQ 3 ACPI IRQ Holder for PCI IRQ Steering
IRQ 10 Intel(r) 82801BA/BAM USB Universal Host Controller 1
IRQ 10 ACPI IRQ Holder for PCI IRQ Steering
Memory Address 0xF6A00000-0xFEAFFFFF Intel(r) 82801BA PCI Bridge - 244E
Memory Address 0xF6A00000-0xFEAFFFFF 3dfx Voodoo Series
IRQ 11 Intel(r) 82801BA/BAM USB Universal Host Controller 2
IRQ 11 ACPI IRQ Holder for PCI IRQ Steering
I/O Port 0x03F6-0x03F6 Intel(r) 82801BA Ultra ATA Storage Controller
I/O Port 0x03F6-0x03F6 Primary IDE controller (dual fifo)
I/O Port 0x01F0-0x01F7 Intel(r) 82801BA Ultra ATA Storage Controller
I/O Port 0x01F0-0x01F7 Primary IDE controller (dual fifo)
I/O Port 0xFFA0-0xFFAF Intel(r) 82801BA Ultra ATA Storage Controller
I/O Port 0xFFA0-0xFFAF Primary IDE controller (dual fifo)
IRQ 14 Intel(r) 82801BA Ultra ATA Storage Controller
IRQ 14 Primary IDE controller (dual fifo)
IRQ 9 SCI IRQ used by ACPI bus
IRQ 9 Creative SB Live! series
IRQ 9 Intel(r) 82801BA/BAM SMBus Controller - 2443
IRQ 9 ACPI IRQ Holder for PCI IRQ Steering
IRQ 15 Intel(r) 82801BA Ultra ATA Storage Controller
IRQ 15 Secondary IDE controller (dual fifo)
I/O Port 0x0376-0x0376 Intel(r) 82801BA Ultra ATA Storage Controller
I/O Port 0x0376-0x0376 Secondary IDE controller (dual fifo)
I/O Port 0x0170-0x0177 Intel(r) 82801BA Ultra ATA Storage Controller
I/O Port 0x0170-0x0177 Secondary IDE controller (dual fifo)
There is more but I do not have the modem and the Geforce 3 in at the moment... I setup a multilink on my old comp so i could download have not put the parts back in yet...
but for the most part thats the main ones that never go away I have tried changeing the resources but it will not change..
As for previous video driver i think i already did.
and my bios is at the latest did that last month.
Thank You,
Sir MMPD
G T i
From those conflicts listed, it doesn't seem like you have a clean install at all. That voodoo driver is totally out of place. Do you still have that card installed? Upgrading an OS doesn't equal a clean install. :p
S
Sir MMPD
USA, CA
Well Fresh install I already did that over 30 reformats...
and the V5 has to stay tell the AGP is working... otherwise I cannot boot up unless its 16 colors.. 640 x 480
:confused:
currently I have the Geforce 3 in my old comp since i had to put the V5 in the new one....
I will put the parts back in again, and post the results....
Thank you,
Sir MMPD
System Specs
DVD: Creative
CD RW: Creative
S
Sir MMPD
USA, CA
Ok I have put all the parts back in and now I am in 16 colors 640 x 480 .
New conflict list.... it sure likes to grow
IRQ 3 U.S. Robotics 56K Fax PCI
IRQ 5 Intel(r) 82801BA/BAM USB Universal Host Controller 1
IRQ 5 ACPI IRQ Holder for PCI IRQ Steering
IRQ 10 Creative SB Live! series
IRQ 10 Intel(r) 82801BA/BAM SMBus Controller - 2443
Memory Address 0x0000-0xFFFF NVIDIA GeForce3
Memory Address 0x0000-0xFFFF System board extension for ACPI BIOS
IRQ 11 NVIDIA GeForce3
IRQ 7 Creative SB16 Emulation
IRQ 7 Printer Port (LPT1)
IRQ 9 Intel(r) 82801BA/BAM USB Universal Host Controller 2
Thank you,
Sir MMPD
