Anyone know how to make a voltage mod on a MSI K7T - turbo raid?
cooleee
Anyone know how to make a voltage mod on a MSI K7T - turbo raid? Cause i want to push my processor beyond 1,85 volts..
Why would you want to go above 1.85 V?
I have my at 1.7 V. MSI K7T TurboR TB AXIA Y [email protected]. The issue for me at this point is the stabilty of the 5 V line...as speed goes up, 5 V goes down and temp goes up.
What voltage regulator is that motherboard equipped with?
I may know where to get the info. for the Vmod, but I don't know what V reg. the board is equipped with, cooleee.
T
Why i want to raise volt to over 1.85 volt?.. cause i can oc even more that way. :))
V reg?.. not sure what u mean..
V reg is the voltage regulator. That's the one you'll have to modify in order to get higher vcore than 1.85. So, you'd have to know which one it is. I guess it isn't the sc1155, as on k7t pro2.
Justy303 (Jun 01, 2001 04:35 a.m.):
Where do you look for a SC1155?
