Anyone Know the Possible Next Gen Gaming Minimum requirements
mrathb
hello everyone im matthew i decided to post this topic because i just purchased dead rising 3 for 15 quid before i found out my pc wasnt good enough to play it properly and dr3 is being classed by alot of people as a Next gen game because it requirements are rather high i didnt want to upgrade my pc upto its minimum incase most of the other future games that are released need even more powerful but didnt want to spend alot of money to go with the recommended if i could get even better spec for similar money
because its minimum requirements are rather high compared to all other games out ive seen or played it made me wonder if anyone knew what would be the minimum or future proof spec people should start to make there pcs
DEAD RISING 3
Minimum:
OS: Windows 7 64-bit edition, Windows 8 64-bit edition
Processor: Intel Core i3-3220 @ 3.30GHz (or Intel Core 2 Quad Q9550 @ 2.83GHz) / AMD Phenom II X4 945 @ 3.00 GHz or higher
Memory: 6 GB RAM
Graphics: NVIDIA® GeForce® GTX 570 / AMD Radeon 7870 or higher
DirectX: Version 11
Network: Broadband Internet connection
Hard Drive: 30 GB available space
Sound Card: DirectX 11 Compatible sound card
Additional Notes: Broadband internet connection is required for Co-op play.
Recommended:
Processor: Intel Core i5-4570 CPU @ 3.20GHz or AMD equivalent
Memory: 8 GB RAM
Graphics: NVIDIA® GeForce GTX 670 2GB / AMD Radeon 7970 2GB
DirectX: Version 11
Additional Notes: Broadband internet connection is required for Co-op play. An Xbox 360 Controller for Windows or other Xinput-compatible controller is recommended for this game.
i built mine a few years ago i was hoping it would of lasted another year before needing upgrading even if i played some games on minimum settings (call me an optimist haha)
my spec is
XFX ProSeries Core Edition 850W 80 Plus Bronze ATX Power Supply
http://www.ebay.co.uk/itm/like/1814...f11=ICEP3.0.0&ff12=67&ff13=80&ff14=108&ff19=0
GA-990FXA-UD7
http://www.gigabyte.com/products/product-page.aspx?pid=3880
Amd Phenom Ii X6 1090t 3.2 Ghz Six Core
http://products.amd.com/en-us/desktopcpudetail.aspx?id=640
XMS3 — 4GB DDR3 Memory Module X2 = 8GB total
http://www.corsair.com/en-gb/cmx4gx3m1a1600c9
VTX3D AMD Radeon HD 6670 1GB With built on Tv Tuner (i know it was a cheap budget one i only had £40 left in my budget so this was best i could afford at the time)
http://www.amazon.co.uk/VTX3D-Radeon-Graphics-PCI-Express-Accelerated/dp/B005J3EPFO
i also have 2x 500gb hdds Sata
and 1 160gb sata all at 5900rpm 2 from previous pcs i have been given or taken apart for parts in past
i havent overclocked anything as my cpu cooler and heatsink are stock and didnt want to risk the parts burning out as my motherboard doesnt have any onboard graphics so if my graphics dies im computerless until could get a replacement
put thr cpu underwater, clock it to 4.0 and add a 280x gpu and i would think your set for a while.
At this point it's impossible to say. When mantle and dx12 are fully utilized, games may make huge leaps. Right now, crysis 3 based games are the most demanding, and I would use that as a baseline.
Your gpu is gonna be your limiting factor at the moment.
That graphics card and the old Phenom CPU are both limiting factors for demanding games. You'll need to upgrade both + the motherboard to have something comfortably powerful enough. The 8GB RAM is ok.
The minimum "future proof" spec I would go for if you want a system that'll last you a few years would be something like this:
i7 4790K
ASUS Z97A/ Gigabyte Z97XUD4H/ ASRock Z97 Extreme6
2x8GB DDR3 (2x4 is fine for now though)
240GB SSD
1TB HDD
R9 290 or GTX 780 *non Ti
