They evidently came out with a BIOS upgrade (ver. 2.5), which I downloaded and installed. I noticed, however, that there were "beta" BIOS available that gave more multiplier speeds and more control over voltage (V. 10b16). I downloaded those and attempted to install, but the Award BIOS flash .exe always stops when it gets to the point of flashing the BIOS (rebooting with a custom made WINME boot disk with only IO.SYS, MSDOS.SYS and COMMAND.COm on it).
Any ideas or anyone try it and get it to work? The regular 2.5 update was installed using Winflash, so no reboot with floppy.
As flaky as this MOBO tends to be I can't imagine that stability would be increased... but I wanted to try...
Thanks for reading
Chris
Thanks for reading
Chris
