Anyone use DVD Decrypter?
autoMATTic
Detroit, MI
I use this program so I can watch my dvds without the disc and I use Leadtek WinfastDVD to watch the vob files. My question is when I ever I try to decrypt Bad Boys II its in french. All except VTS_01_6 is in french and thats only like the last chapter and the end title. Anyone know what I can do to fix this?
I have the same problem with my cowboy bebop dvd....
Someone out there knows
Theres probably just a different program you have to use.
I've used it before to copy DVDs. I haven't used it in a while but there should be a section that allows you to select which audio file that you use. When I have the time I'll play around with it a let you know if you haven't figured it out by then.
Ok i figured it out.
Under Mode (in the toolbar at the top) go to IFO. Then that way you can deselect the laguanges you dont want in the main movie file. That part is under Stream Processing.
