- Feb 12, 2001
- So Cal.USA.
I was wondering if it stays purple, I have heard it turns clear after a while?
TIA.
TIA.
Rottys-R-Us said:That stinkz, it would have looked KEWL.
Thanks.![]()
SHODAN said:
I'm with you on that! I just started looking for purple dye, either regular or UV reactive, but I haven't found either yet. I'm also hoping to find a bright orange dye and the closest I've found is the "Fire Red UV Dye" at D-TEK, which doesn't look very bright to me. Let me know if you find any of these, and I'll do the same.
Rottys-R-Us said:
I like the idea and look of it but, I would need / like it to be big enough to hold the pump in it tooRottys-R-Us said:
Rottys-R-Us said:
