Anyway to increase the memory frequency Powerstrip allows?
Tipycol
Well, I've tried OC'ing an AIW Radeon 7500. From a stock of 258/180, I've got it stable at 290/239 (fine at 300/239, but I wanna keep it at 290 for now ;)). The only problem is that I can't get the memory any higher than 239, due to the fact Powerstrip caps at that point. Is there anyway to get it higher?
Clicky on the boxes.
-PC
Wow, when I read that I thought you had reached the max memory speed Powerstrip allowed. The max in Powerstrip for me would blow up my card for sure!
lol i wish ;)
But now I have another problem (I think). Powerstrip doesn't seem to like having my GPU clocked at 280-300MHz. Every time I restart the computer, the frequency becomes 228, but the memory stays at 240. Anyone know why this happens? Does this mean the OC isn't stable?
Tipycol
Cullam3n said:
I think it's because you didn't check the startup box.
-PC
Do you mean I have to start powerstrip every time I turn on the comp? Or is the startup box something else?
Cullam3n said:
I believe that you should put PowerStrip in your startup, but I could be wrong.
-PC
Well, maybe it meant my OC was not stable, cause when I set it to 280MHz, it stayed. Wonder what's wrong with it at 290Mhz :(
