- Oct 2, 2002
- Hazel Park, MI
but i made it a lil bit better.... check this:
took off the HS on my Aopen GF Ti4200.... and OMG under it was what looked like a white blob of calking the size of a wad of chewing gum... (didnt think to take a picture till after i wiped it off..musta' been the shock of seeing that, that made me forget
and here is what it looked like after i cleaned off the white crap...
well as you can see it was pretty damn ruff under there so i busted out the sand paper and lapped the sucker... looks like its crappy crome painted, then under that was crappy copper plateing super thin then true metal.... and here's what i ended with after about 30min of sanding
so now i've put my AS3 on it and put her back into the PC and will now try and run some 3DMark and see if i get anything better than what i was before (310/600) even if I dont i feel better knowing that its AS3 on and is lapped
