- May 15, 2006
That isn't exactly a combination most would want to find themselves in, but this is the hardware I have and the software I'm running.
OS:
Flavor - Arch Linux
Kernel - linux-3.3.7-1
ALSA version - 1.0.24
Hardware:
Auzentech Prelude (same hardware as Creative X-Fi)
Files:
FLAC, mix of 16 and 24 bit
I've run into an interesting problem on my new computer. Using different audio players (Amarok and DeaDBeeF), music will suddenly stop playing between songs, with no rhyme or reason. Both are pulling from the same music location (CIFS share to my file server) and the same exact files. Even copying the files locally (to ~) produces the same problem. Originally, I thought it was because of an error, so I've been using multitail to watch (/var/log) messages.log, errors.log, and everything.log. While listening to music and when it stops playing, there is absolutely no activity in any of these files. I got clever and started running both players from a terminal (see below) and they don't mention anything about errors. After some time (usually x2 the song length), Amarok will suddenly start playing again, completely skip the song it was going to play and usually ends up one or two songs down the queue. DeaDBeeF just stops dead. I've tried both programs on a completely clean config folder and they produce the same results. The files are not corrupted as they play perfectly fine on my laptop, which is running the exact same operating system, kernel, ALSA version and music player. The only difference is the sound hardware. This has me completely perplexed as to what is going wrong and I've made a few attempts at poking the system to see if I can get it working.
What I did notice today, however, is the issue seems to be when it switches from a 16 bit file to a 24 bit one. Here is the log of a lockup. The red is what was added to the log right before it stopped working.
I was reading something the other day that said there was an issue with ALSA switching from 16 to 24 bit, but I can't remember where I saw it and I can't locate it in my history.
Ideas?
OS:
Flavor - Arch Linux
Hardware:
Files:
Code:
starting deadbeef 0.5.4
server_start
loading plugins from /home/thideras/.local/lib/deadbeef
loading plugins from /usr/lib/deadbeef
plug_load_all: scandir found 163 files
loading plugin /usr/lib/deadbeef/aac.so
loading plugin /usr/lib/deadbeef/adplug.so
loading plugin /usr/lib/deadbeef/alsa.so
loading plugin /usr/lib/deadbeef/artwork.so
loading plugin /usr/lib/deadbeef/cdda.so
loading plugin /usr/lib/deadbeef/converter.so
loading plugin /usr/lib/deadbeef/converter_gtk2.so
loading plugin /usr/lib/deadbeef/dca.so
loading plugin /usr/lib/deadbeef/ddb_ao.so
loading plugin /usr/lib/deadbeef/ddb_dumb.so
found gui plugin ddb_gui_GTK2.so
added GTK2 gui plugin
loading plugin /usr/lib/deadbeef/ddb_mono2stereo.so
loading plugin /usr/lib/deadbeef/ddb_shn.so
loading plugin /usr/lib/deadbeef/dsp_libsrc.so
loading plugin /usr/lib/deadbeef/ffap.so
loading plugin /usr/lib/deadbeef/ffmpeg.so
loading plugin /usr/lib/deadbeef/flac.so
loading plugin /usr/lib/deadbeef/gme.so
loading plugin /usr/lib/deadbeef/hotkeys.so
loading plugin /usr/lib/deadbeef/lastfm.so
loading plugin /usr/lib/deadbeef/m3u.so
loading plugin /usr/lib/deadbeef/mms.so
loading plugin /usr/lib/deadbeef/mpgmad.so
loading plugin /usr/lib/deadbeef/musepack.so
loading plugin /usr/lib/deadbeef/notify.so
loading plugin /usr/lib/deadbeef/nullout.so
loading plugin /usr/lib/deadbeef/oss.so
loading plugin /usr/lib/deadbeef/pulse.so
loading plugin /usr/lib/deadbeef/shellexec.so
loading plugin /usr/lib/deadbeef/shellexecui_gtk2.so
loading plugin /usr/lib/deadbeef/sid.so
loading plugin /usr/lib/deadbeef/sndfile.so
loading plugin /usr/lib/deadbeef/supereq.so
loading plugin /usr/lib/deadbeef/tta.so
loading plugin /usr/lib/deadbeef/vfs_curl.so
loading plugin /usr/lib/deadbeef/vfs_zip.so
dlopen error: libzip.so.2: cannot open shared object file: No such file or directory
trying /usr/lib/deadbeef/vfs_zip.fallback.so...
plugin not found or failed to load
loading plugin /usr/lib/deadbeef/vorbis.so
loading plugin /usr/lib/deadbeef/vtx.so
loading plugin /usr/lib/deadbeef/wavpack.so
loading plugin /usr/lib/deadbeef/wildmidi.so
checking GUI plugin: GTK2
found selected GUI plugin: GTK2
loading plugin /usr/lib/deadbeef/ddb_gui_GTK2.so
libWildMidi(WM_BufferFile:640): ERROR Unable to stat /etc/timidity/freepats/freepats.cfg (No such file or directory)
gtkui plugin compiled for gtk version: 2.24.10
selected output plugin: ALSA output plugin
INFO: loading playlist Main
INFO: from file /home/thideras/.config/deadbeef/playlists/0.dbpl
INFO: loading playlist Local
INFO: from file /home/thideras/.config/deadbeef/playlists/1.dbpl
streamer_set_output_format 16bit int 2ch 44100Hz channelmask=3, bufferfill: 0
palsa_setformat 16bit int 2ch 44100Hz channelmask=3
gtkui: found cover-art loader plugin
alsa_soundcard: default
chosen sample format: 0002h
chosen samplerate: 44100 Hz
minchan: 1, maxchan: 10000
setting chan=2
alsa channels: 2
trying buffer size: 8192 frames
trying period size: 1024 frames
alsa buffer size: 8192 frames
alsa period size: 1024 frames
chosen bps: 16 (int)
alsa avail_min: 1024 frames
[COLOR=Red]streamer_set_output_format 24bit int 2ch 96000Hz channelmask=3, bufferfill: 0
palsa_setformat 24bit int 2ch 96000Hz channelmask=3
chosen sample format: 0020h
chosen samplerate: 96000 Hz
setting chan=2
alsa channels: 2
chosen bps: 24 (int)
new format 24bit int 2ch 96000Hz channelmask=3
palsa_free
waiting for alsa thread to finish
Segmentation Fault[/COLOR]
Code:
[root@pascal log]# lsmod | grep snd
snd_hda_codec_hdmi 24120 4
snd_hda_codec_realtek 114123 1
snd_hda_intel 23989 2
snd_hda_codec 92713 3 snd_hda_intel,snd_hda_codec_realtek,snd_hda_codec_hdmi
snd_ctxfi 96928 2
snd_hwdep 6556 1 snd_hda_codec
snd_pcm 74812 5 snd_ctxfi,snd_hda_codec,snd_hda_intel,snd_hda_codec_hdmi
snd_page_alloc 7217 3 snd_pcm,snd_ctxfi,snd_hda_intel
snd_timer 19222 1 snd_pcm
snd 59656 15 snd_timer,snd_pcm,snd_hwdep,snd_ctxfi,snd_hda_codec,snd_hda_intel,snd_hda_codec_realtek,snd_hda_codec_hdmi
soundcore 6082 1 snd
Ideas?
