Starfox said:
youd think the guy would be smart enought o whipe
the AS off. lol![]()
If you have Arctic Silver Adhesive on your chipset, that's epoxy. It won't wipe off nor will a solvent cut it.
Bubba said:I need to remove the AS adhesive from my chipset.(I have way tooo much) how can I get it off or what should I use.Is the top of the chipset fairly durable?
