As the title implies, I am looking to slap an Accelero Extreme IV on a EVGA 1080ti FTW3 which started it's life off as a hybrid version. From there, I converted it to a custom loop using an EK waterblock and now for some strange reason, I am moving back towards minimalist tendencies. I just want to move my rig back to 100% air and not have to worry about flushing, changing coolant, dying pumps, fan hubs, and having to tear everything apart to replace 1 thing because it's mounted under all of the watercooling equipement like a fan(s) from Corsair who can't seem to work our their RGB woes after over a year of iCue.
Sorry for the rant - my question is simple: with the FTW3 card being rated at 280 TDP, will the 300 TDP Accelero be good enough, or is that not enough headroom at the top? I will NOT be doing any GPU overclocking, i just want to make sure this will keep it cool and if i get temp results comparable to that of the stock EVGA cooler, that's fine. There's going to be ample airflow in the case. Also, does anyone have thoughts on the topside heatsink and its VRM cooling capabilities? would it be sufficient or would pasting additional heatsinks on the actual VRM be advised? Thanks in advance for responses!
