So I’ve had to modify my case to make this cooler fit, no biggie couple holes drilled.
my question is do I plug the 4 pin connector to the cpu fan header or to the aio header?
the 4 pin wire controls the pump and fans. The other wire is for rgb, not sure where to plug that in either, if I even will. The solid black one, no rgb, was a week to get from Amazon so I got this one.
from what I’ve read it can go either way.
if plugged in to aio header the pump and fans run at 100%.
i don’t care personally, but I’ve never messed with aio before.
‘’if nothing is plugged in to cpu header will I get warnings / issues?
i could plug the top exhaust fans into that header I guess instead of a chassis fan header.
