Are all of these cpus are unlocked ??
S
S14SR
ptwearnhardtfan said:
The trouble with buying it at newegg is that you just don't know.
How will I know if its unlocked or not ?
glock19owner
change the CPU Multiplier and then reboot...what the BIOS when it boots up...it should say what multi. and FSB you are running...if it is at the multi. you set it at...it is unlocked...if not, then you might need to update to the latest BIOS or your MB just wont support the tbred unlock...not all MB will support the unlock...but you should be able to with the lates BIOS if you are not already running it...
S
S14SR
You mean CPU Frequncy Multiple ?? and if so, what should I change it too ??
BTW, I have Asus A7V333R with Bios 1016.
pip
Oregon, The InteLinux State
xX~EXCELSIOR~Xx said:
just read teh stepping
if it says AIHUB then its a core
if it says JIHUB then its b
wrong if it's an AIUHB it's B if it's JIUHB it's B if it's AIUGA it's A if it's AROIA it's A if it's AKOKA it's A if it's AIUCB it's B if it's JIUCB it's B
S
S14SR
I really hope Im going to get the B stepping, or Im going to send it back.
Does anyone knows how far will A stepping go ?
glock19owner
Yes, and to something other then default to see if it works...
And the A's do not OC very well at all...between 1.7 and 1.8...if you are lucky, maybe around 2G...
LittlePiggie
Oregon
all of the L1 bridges will be connected on the chip if it is unlocked. easy, simple, and you can check it without opening the package. :D
