stevens said:
I already have all the barbs and everything and i was planning on doing it myself. I already have one fixed up but it doesnt fit, so i got one off ebay that was supposedley the right size but they sent me a different one. So are you saying that the Black ice could give me 3-4 C off a difference? that seems like a pretty big difference.
would u pay 60+ dollars more for a few degrees? (im not totaly sure what the difference would be, a guess)
IMO if the ebay heatercore is bigger and you get alot of air passing through it, it should be just as good. unless your gonna oc like a mad man, a few degrees wont kill you, unless u need them and to waste that extra money. i get 37c (25c case temp) idle at stock speeds with a crapy 12x5 alum rad.. so that heatercore that u and i have should be better then that dont you think? and for having a water mix of likr 60% anti freez (i wasnt paying attenion while pouring) i get pretty darn good temps with a crappy gettho 20min setup i did.
so im just trying to save you $$$. and i just believe that if your gonna go through all this trouble to water cool, you may as well custom make some parts. cuz water cooling gets useless to a point if you spend so much money. a 60 dollar hsf will get you pretty close to what a crappy watercooling setup thats twice the price.
so im just thinking commen sence, and trying to save you $$.
you dont have to go with my ideas, but im just hoping you think hard be4 u go buying whatever u see at first. (what i did, and now i gotta re-do it all
