Are the Blue Thermaltake Ramsinks good enuf form my 8500?
Starfoxer
World's Biggest E-Thug
USA
none of them really make too much difference heat wise
but those are just as good as any other. maybe even
perdier :p make sure to have a fan blowing right on em.
Maximus Nickus
Senior Shaman
Milton Keynes, U.K.
They should be okay if you attach them with Arctic Alumina and not the tape:rolleyes:
Even the Tin Plated copper Ramsinks don't give that much of a performance increase unless you don't have a well ventilated case. (Then they help!)
8500's are often held back from the voltage...
They should be fine,
Maximus Nickus
E
EclipseJP
In front of my Computer
Thanks guys. I have artic alumina and artic silver thermal compound. I think that Ill use the silver compound. I have a delta from my thermosonic thermoengine blowing on them with all 7200 rpms. I have it hooked up to the digi doc so I can turn it off when it gets too loud. :)
